The 4800 will definitely hold both kits. The Apache cases come with Pick n pluck foam so someone initially doesn’t have to go searching for foam. However there is better foam out there if you can find it. In defense of the pic and pluck foam I did use it for packing three decent size studio strobes in a large pelican case for years before the foam fell apart. But again, I think if the controller or controllers can be stood up a 3800 being smaller might be sufficient. If the size of the case doesn’t matter then the 4800 might be a better choice.You can try the Apache 4800 which is bigger than the 3800.
I've always asked myself the same question. Why polyurethane foam is so darn expensive? Almost any big package transported now day is protected with it and is always disposed.The 4800 will definitely hold both kits. The Apache cases come with Pick n pluck foam so someone initially doesn’t have to go searching for foam. However there is better foam out there if you can find it. In defense of the pic and pluck foam I did use it for packing three decent size studio strobes in a large pelican case for years before the foam fell apart. But again, I think if the controller or controllers can be stood up a 3800 being smaller might be sufficient. If the size of the case doesn’t matter then the 4800 might be a better choice.
As I look up the cost of polyurethane foam I’m shocked at the cost for just solid pieces of the stuff. As I think about it I’m wondering that if I went down to the local guitar store they might have tons of foam that they’re putting in the dumpster every night? I could be wrong but I think it would be interesting to find out if my assumption is correct.
