Come on DJI. Goggles 3 and Mavic Classic
4 inch pistons
eastern NC
I see where the Goggles 3 now work with the Mavic 3 Pro but not the Classic. Before I bought the Classic I read that the only difference in the two was the cameras. So why doesn’t it work on both?
i wonder how much extra time is put in to keep euipment from working on oyher drones ,why not one goggle that works on any dji drome ,is it about the money or is it that hard to do ??
Having lots of experience with software development, my guess is no effort is put in to keeping thing from working together... It's quite the opposite, there's usually some work necessary to get each variant of some product family to work with something new.
Often the reason is technically trivial, like adding the new device to places in the code that get the model or some other identifier, and then make some sort of choice as to what code to execute. It can point to exactly the same code to execute as for an already supported model, but the branching code must be updated to do that. See the "switch" statement in Java.
Depending on the design of the code, there may be many of these, so the engineering effort to support a new model of something can be non-trivial, even if the code to implement that support is technically trivial, while tedious and time-consuming to implement.
The decision not to make this effort is a strategic marketing one, or driven by ROI.
Depending on the design of the code, there may be many of these, so the engineering effort to support a new model of something can be non-trivial, even if the code to implement that support is trivial.
thanks i don,t need to wonder about things i don,t completely understand and don,t use it for a reason to mistrust ,I think i got to the point there
Just wanted to dispel the notion that DJI is doing something sinister, when there is a far more common (and likely) reason.
Badeff
