Complete beginner here.
From California, US - @Dapper Dan - Thanks for joining us @ MP!
A lot may depend on what you want to use it for. Recreational flights or monetary flights. Also, you'll have to look into the rules and regulations Australia's Aviation Administration have for drone flights.
Small ones could be something like the Mini 4 Pro, something a little larger would be something like the Mavic 3. Others will likely come on to share their view of things too.
I would appreciate any input on what to buy - or not to buy - as my first drone. This must be a very common question I know, but any input would be gratefully received. How shall I put this ... "I'm shopping on a budget". I'm in Central Queensland, Australia ..... thanks in advance.
Good morning and welcome from Warwickshire in the UK. You have quite a few options.
Small form factor:
Mini 2 (cheapest, still a very capable general purpose drone).
Mini 3 series (excellent camera and a big step up in features).
Mini 4 pro (most expensive but enough of an upgrade in camera quality and transmission signal technology to warrant the cost).
Then the larger drones like the Air series.
Air 2S (still in production and used extensively, carries a 20mp sensor, excellent still & video quality, good middleweight design but limits you regarding where you can use it legally)
Air 3 (startling upgrade regarding camera layout and the same bomb-proof O4 transmission signal as the Mini 4).
But there are also older middleweight drones like the original Mavic Pro: the Mavic 2 Pro and Zoom, getting parts and batteries for these is becoming difficult, but they are cheaper than the newer models and still perform extremely well, but the O2 control signal can be flakey when used in urban environments due to an increasing amount of WiFi noise generated from pretty much every wireless electronic device crammed into every single house/apartment in every city, town and village on the planet.
Welcome.
My vote second hand mini 2.
But whatever you buy, if it second hand ENSURE that is it unbound by the original owner. "Binding" is an association between
A) the drone and the pilot's DJI account and
B) the controller and the drone.
It can ground a drone if the control app is not logged into the original pilot's DJI account.
It is NOT the connection, between the drone and the controller, that is used for control purposes which is referred to as pairing or linking.
I suggest you google "drone bound to other account".
If you are thinking of a FLY app using drone and will be using a phone etc to run FLY check NOW whether or not your phone will run FLY.
Download fly from DJI Fly - Download Center - DJI
Welcome from the Houston Texas area. I cut my teeth on toy grade drones such as sky vipers. Crashed a few and lost one but it was a good learning experience. I got my Mavic Pro on Ebay for $500 USD delivered. i still fly it and love it. one day when I grow up (and can afford it) I will buy a new drone but for starters a used one may be the way to go
Welcome to the forum from the beautiful woods of Maine,USA!
I would recommend the Mini 2 so you don’t spend a lot for a hobby you may not like or have difficulty operating. My second entry into drone flying started with a Mini and eventually graduated to an Air 2. The Air 2 is enough for my use, I’m not a photographer and don’t post many videos.
I agree with PropWash, it all depends on what you plan to use it for and a Mini 2 is a good entry level drone.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Once you decide on which drone to buy and fly, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Fly On and Fly Safe…
You must define the purpose of flying. sUAV. That will determine your budget. If you need high quality stills or video, then you need to buy high end.
Greetings: from Chicago the Windy City, welcome to the forum.
FLY SAFE & FLY SMART
I have the MM2, I love it because it's people friendly.
Also, have the Mavic pro, with the Remote ID, I fly it in rural area's.
When I started I bought a mini 2. Doesn’t have obstacle avoidance but a terrific little drone taking lovely videos and you should be able to pick one up for $400-450. Practice heaps on a footy oval or somewhere there are no powerlines or trees. I had a terrific time learning on that for 12 months and then sold it and now have an Air2s. Take a look on Marketplace to see what’s for sale and what you can afford then Google reviews on the ones that interest you. Good luck. You are going to get hooked.
osje
