Connecting the MA2 to a Feel World display?
Don’t know it it’s correct, but someone on this forum said the CrystalSky is a 32 bit device, whereas the Fly app requires 64 bits.
Yes, I know it won't work with the Fly app, but I bet that it will with Litchi once they update it. Just as the Mini works with Litchi.
Thor’s Droneworld shows a solution. I’m sure the connecting device etc is available without the monitor and mount./
Thor’s Droneworld solution, see above, works well With Mavic 2 Pro and earlier models that use a similar RC. The issue with the MA2 is finding a way to mount the monitor because the attached battery sticks out so far. You can’t use the regular holder and even if you could, you’d still have to find somewhere else to mount your phone because the monitor cannot run ANDROID OR IOS apps. Tore from thorsdroneworld has told me he may be able to find a solution for the MA2 Baldur mount.
pashuter
