Controller doesn't charge
bugs
I never had any problems charging the controller. But now he doesn´t recognize any cable...I tried everything, changing cables but in the end nothing! Since the controller has low battery e even doesn't let me make some updates, wich at this time I don't Know has nothing to do with it.
If anyone could help me with any sugestion I will be thankful!
try moving the charging port around. sometimes it doesn't get a good connection. I have had such an experience before
Tks Seanv100...but I recharged the batteries from the drone and work perfectly. However, as you imagine, at this time I try everything and I took you're suggestion. Nothing!
The charging port was probably damaged. Bad news is, this is pretty expensive to fix.
hughesthis
