Nothing special. Just some quick post work on a rainy day.
by the look of those lines left in the field that was some great combine drivingNothing special. Just some quick post work on a rainy day.
Interesting look at our food chain! Great flying! Long enough to cover the subject, but short enough to keep my interest.Nothing special. Just some quick post work on a rainy day.
Very nice! So did you fade in and then fade out with some sort of sepia transition at the start and finish?Nothing special. Just some quick post work on a rainy day.
Yes, I thought the same thing. These are obviously professionals hired to harvest the field. I don't think they are local as from "just down the road".by the look of those lines left in the field that was some great combine driving
I'm using FCPX. For fade in and out, FCPX offers a "fade to color" transition. But I don't like it. It's too abrupt. So I generate my own fade by setting key frames and change the exposure to/from zero.Very nice! So did you fade in and then fade out with some sort of sepia transition at the start and finish?
nice... better than mine! i crashed at endNothing special. Just some quick post work on a rainy day.
Sorry to see the crash. You did a lot more comprehensive flying than I did. I was kinda lazy. And I didn't get too close so as not to make the farmer upset at drones! They shoot things like that around here!nice... better than mine! i crashed at end
Great ideas! Thanks. I need to do my homework.Thanks for sharing. Nicely done. A cool angle, if circumstances allowed it, fly low toward the wheat harvester. Would work as a possible reveal shot: Camera down, flying forward, and slowly raise the camera up.
FCPX Fade To Black from memory /-: Not sure if you tried these and if they would work for the effect you wanted?
Try “alt + w” adds in a gap between clips. Next, adjust the duration. Use “Cmd + t” adds two transitions before & after the gap clip. Or...
Go to the generator, select solid custom (Default is black.), drag between clips, adjust duration. Add Fade to Color before and after.
I hear that most modern combines and farm tractors have GPS auto steer.by the look of those lines left in the field that was some great combine driving
Thanks for explanation!I'm using FCPX. For fade in and out, FCPX offers a "fade to color" transition. But I don't like it. It's too abrupt. So I generate my own fade by setting key frames and change the exposure to/from zero.
