CPL filter
mfarris2
USA
Does anyone know of a decent CPL filter for the Mavic that is decently priced? And you actually have a lens that rotates,....after snapping on the filter. I purchased this drone for the extra distance VS the Phantom 4 Pro. But I still want to get decent footage. I am king of afraid of pulling the trigger on a circular polarizer if I have to turn the whole filter against the camera. (Not the most rugged camera I've come across.)
Thanks for any suggestions in advance.
For the best shots I recommend polar pros nd8/pl for cloudy days and the nd16/pl for sunny days. You will not be able to rotate a cpl filter after your bird has left the ground.
Reactions: dronanObrien
why does it need to be for every shot?
power up gimbal, small mark at the top, orientate the filter to where it works, place mark, then power down and fit?
Reactions: grizzard
Thank you. I just want to be sure I was not rotating the entire aluminum housing for the filter. Hate to tear up the camera while trying to rotate the tight glass housing.
idiogenic is right; CPL is very weak fit for drone usage, unless you had a radio-controlled way of rotating the filter per each shot. The only way that makes sense is to orient it so that horizontal surfaces glare least when facing the same way on the ground that you'll face in the air. But that's only a tiny fraction of what a CPL could do when working with the camera directly.
There are two (2) types of polarizing filters, linear and circular. Circular polarizing filters are essentially linear polarizers, with a second glass element attached to their back that circularly polarizes the light, giving accurate exposure results when the light hits the light meter. When the two elements are aligned at the right handle and orientation from the sun, the captured image could have more saturated colors, bluer skies, less reflections and higher overall contrast. Unfortunately, you cannot be there to rotate the filter so using a circular polarizer bring little value.
I love the combination filters as I previously stated "nd8/pl for cloudy days and the nd16/pl for sunny days." These types of filters knock down (stops) the light so it is more manageable and add saturation so the greens are greener and the blues are bluer. But the real value from the polarizer comes into play by cutting surface reflections on water.
Whatever filters you decide on, make sure you know whether they can be affixed to the lens before or must be put on after gimbal initialization. The newer filters do not interfere with the gimbal startup routine.
Reactions: bakerboy
I shot these 2 weeks ago on a 92 degrees day in Costa Rica with a Polar Pro ND16 don't remember is they are PL. No post, straight out of the Mavic. It was so bright out that I could hardly see the display of my iPhone 7Plus. When I landed the Mavic to swap batteries I had to let it cool down for a few minutes as the motors were so hot to the touch. She is such a trooper the way she handled the heat.
To the OP - I have a Polar Pro CPL that I do not have use for it. It came in a set, I am mostly using the ND8 and the ND16. All of the filters pass calibration, I install them before power up and leave them on. If you are interested make me a reasonable offer for just that one filter.
Maybe everyone should read this to understand the difference: All about Polarizers - Linear and Circular
Dark sky with any type of polarizer is only seen when the camera is at an right angle to the direction of the sun.
A circular polarizer also needs to be adjusted to reduce glare when you are change the camera angle relative to the sun.
Reactions: Helo
Give me a price. I am interested.
In addition to being sensitive to the angle to the sun, cameras with wide angle lenses can produce images where the sky goes from light to dark horizontally even when shot at or close to 90°. About the only work around is to try to patch it with a gradient filter in post, very hard to do.
Yes,....you see, a circular polarizer clears ups over exposure in a sense. Makes colors pop. It will not be perfect when set for a particular shot,....and then your drone is moved. But as long as you keep the sun in about the same location,....it will certainly help pre-production shots.
Come on! Tell me I am so wrong. Polarizing filter is often placed in front of the camera lens in photography in order to darken skies, manage reflections, or suppress glare from the surface of lakes or the sea. See,.....clear up bright spots and make colors pop!
Nice shots
saskia
