Crash help
pattyson
Canada
I was trying to fly my drone in a tricky situation and I received two error codes it hit a metal culvert and then landed with the battery contacts in water I grabbed it out shortly after a minute dried it out tried starting after an hour got nothing so I booted it up today after drying out and got this any help is appreciated thank you in advance!
Fresh water I presume? Have you got a spare battery? What drone? Likely battery is cactus if water got in it. The drone itself is a bit more resilient... get the battery sorted first and in the meantime keep the drone warm and dry. A wash with denatured alcohol or a spray out with circuit board cleaner may help...
See if you can borrow a battery rather than fork out before you know if the drone is stuffed.
David H
