Crashed mavic 2 Zoom
Mitd9922z
Is it worth sending in a mavic 2 Zoom for repair? One motor broke off and the front cover above the gimbal came off. There's also a crack in the side of the body of the aircraft.1000005875.jpg
Hard hit!
DJI is easy to deal with and very reasonable on repair costs.
Start a repair ticket with them. They will email a shipping label, send you a cost within a few days of when they get your box. If you accept the repair cost, you will end up with a new or like new aircraft.
From what I can see, you have two damaged arms and several body parts that would exceed 150.00 if you acquired those parts yourself. This is assuming the camera isn’t damaged which if it is, you would more than double your parts cost.
I have repaired several M2 series aircraft and although these are one of the easier DJI products to work on, you would be almost completely dismantling this one to fix it. It would require some soldering to replace the arms.
apexaerials
