Crazy crash, gimbal is reversed! Help! *With FIX*
Any fixes on the side to side tilt mine won’t tilt side ways when I’m banking
I FIXED IT!!!
I found a fix on YouTube!!!
Basically you can wedge the joint that connects the cameras to the axis and then it can be rotated back around!!
EVERYTHING WORKS PERFECTLY NOW!!
I've contacted the YouTube poster of the video and will be sending him a donation.
THE REVERSED CAMERA CAN BE FIXED FAIRLY EASILY!!
Thank you for everyone's help and support.
Now.. for the link..
FREAKIN lifesaver
Like if you went side to side it’s like stuck in fpv mode because mine doesn’t compensate for the right left bank not sure if that’s the problem you were having?
Was able to get out an fly it some tonight an yes it seems to have that issue! It won't work from side to side. Works fine up an down tho!
Reactions: Arce101
bradpitt
