Anyone else ever have what seems to be a gimbal malfunction while flying. Is it just the gimbal resetting after the catche? is full
That's funny cause I thought an eagle had got me. And was freaked out cause I was a half mile away from it over a riverSame here. Thought I had a bird strike in mid flight. Happened a couple times at different sites. I did have a filter on each time it went nutz so I don't know if that is an issue. Re-calibrated the gimbal and no problems since. Not sure if calibrating with a filter on is right or wrong but that's what I did last time. I did cut off that yellow plastic tab as I thought it was causing it to hang up.
I just had that happen to mine as well... Flying along fine and all of a sudden it looks like the Mavic is free falling through the air. I thought my motors had quit. Does it 3 or 4 times, then seems to reset itself and work fine. Saved video to the SD card cuts out right before it happens so nothing to show DJI. Has anyone tried contacting DJI about this? I hope this isn't a new "feature.."![]()
