- Joined
- Sep 9, 2018
- Messages
- 312
- Reactions
- 161
- Age
- 51
Hello drone fanatics... just a quick mod idea i did on getting a DJI Crystalsky-QR bracket onto a Mavmount3.0....took me about 1/2hr to do... l got all the hardwareparts for about $14 @ my local HomeDepot... DJI-QR$79, Mavmount3.0 $65, ur gonna need #212 screw eyes or look the size# that will fit the rear eye screw hole on bracket, 6M 1.0x16mm socket hex/cap bolt,16mm tension lock nut if needed)Blue-Locktite, 2/Tap&Drill bit set(as in pics)& 2 deadbolt/door frame brackets(as ur spacer)tongive u a lil'of height/sticks thung clearance,a few beers & a lil time.....! comes out super solid & wont budge a bit, once the rear bracket screw is drilled then taped theeaded with #32bit,screw in#212 eye screw with Locktite or drop of JBweld in threads, align/measure bracket screw hole with bolt, dont tighten in screw just yet...drill/tap #6mm just above 1/4-20 hole on mount, fit mavmount & QR onto controller fiting both bracket & mount flush to controller, make a dot-mark of hole and begin to drill...remove QR bracket, tap ur threads(take ur time)then place deadbolt door spacer/s onto mount while aligning both new holes & thread top 6M bolt 1st then align rear eye-screw to bracket tighten, down both from with Locktie/JBweld drop as u tighten from/rear til it fulsh & even... alow to
dry... mount on ur CS monitor & thats it..... use pics as details....View attachment 59423View attachment 59484View attachment 59485
