Thank you, very well done. Even I understand it.You can achieve this by using the Active Track Intelligent Flight mode. This is assuming that you have a point of interest that you want to fly a half circle around. Just draw a box around the object from within the Active Track mode. Touch GO in the center of that box you drew onscreen. Below that there will be a half crescent shaped line that one can touch and drag. As you drag it to the right the Mavic will fly right at the speed that is noted below the half crescent. Drag it left and the Mavic will fly left at the speed noted.
Hi,
Is there a flight panning app that will make the Mavic fly in a curved path?
^^thisOne of the options in Litchi waypoint missions is curved corners at waypoints. Also, if you draw out a curved path and let Litchi select the waypoints the entire path will be as curvy as you want.
Thats the idea Dougie Doug! Simple to achieve with the tools you already possess.Thank you, very well done. Even I understand it.
Does Dronelink provide the turn-out loops for fixed-wing drones/piloted aircraft? See ExamplesView attachment 91553View attachment 91554
