Detail log file analyzer
goixiz
Who has the most detail log file analyzer that i can run a my log files
Looking for errors and cause and effect analyzer for my dji drone (spark and mavic)
Text only is fine but if it comes with a kml file for graphical visuals will be great as well
Thanks in advance
Reactions: Mike_Flys
For really detailed and high time resolution, only CsvView/DatCon
To get best result, you need to get flight record from the drone itself.
i like the details of the datcon but i it is looking for the dat file which is not as easy as the flightlog.txt. Is there a converter to convert the flightlog.txt to DAT
I was able to locate the DAT file as well but datcon shows as error
No. That wouldn't be possible since TXT files only contain part of the data found in DAT files.
You may have retrieved the wrong type of .DAT. It's easy to do. The correct .DAT files are in the FlightRecords/MCDatFlightRecords folder. Also, the correct .DAT files use capital letters for the extension. I.e. .DAT and not .dat.
Reactions: MavicCF
GOT IT
Now to digest all that info
I receive a disconnection and AC went into RTH mode
I just want to know what caused it so i can make sure it does not happen again
The amount of data was a lot but need to learn how to sort thru the data that causes error of AC - Any hint/advice please post
TIA
BuzoLibre
