Different roll beweeen Portrait and Landscape
Mauri59
I hadn't used the mavic pro in over a year, and while checking to make sure everything was working properly, I realized that the horizon calibration is not right for portrait format, which is tilted about 10°. Even recalibrating the gimball, and the IMU, the problem persists. With the horizon fine in Landascape, I have to correct the roll it if I switch to Portrait. Any idea how to fix, or is it inevitable to manually correct the tilt each time when switching from landscape to portrait format? Thank You.
No reply after eight days....
Let's try to ask the question in a different way: would someone who owns a Mavic Pro 1, be kind enough to check if switching from Landscape to Portrait mode (it's not needed to fly the drone) results in having to correct the roll?
sscott062
