DJI Assistant 2 Buggy or What? (Warning Rant)
MRomine
This has got to be the most buggy software that I have ever tried to use in my life. It was obviously created for use in a Windows environment and has been converted as a 2nd thought to work under the Mac OS.
Nine times out of ten when the Smart Controller says that I need to calibrate the vision sensors, connect the SC to your PC or Mac and run the DJI Assistant 2 it fails 2/3 of the way through the calibration process making me start all over again. Right now I can not get the DJI Assistant 2 to even see my SC when I am connected to my iMac running Mojave 10.14.6 (trying to get a file off the internal SD card). The reason why I'm going this route to download a file is because when I insert the SD card into a card reader connected to the iMac it tells me "The disk you inserted was not readable by this computer". Never had an issue with a SanDisk card before and the SC can read all the files on the card. :mad:
PJ19
