DJI Assistant2 installation. On a Mac, I get an error....Last login: Mon Sep 28 11:53:00 on ttys001
It would be nice if DJI would build and application that doesn't require command line install. I couldn't get it installed either.
Which OS is your Mac using? I had no problems at all.
try with sudo first. --sudo
I have Catalina and could not get it installed. I ended up installing it on my Surface Pro. I needed it to update the Smart Controller so I could use it with the MA2. The Surface Pro worked great. Total time from start of install to takeoff was 25 minutes. I spent that much time trying to get the program to install on my Mac.
iconautomatedsolutions
