DJI disconnected
Sawtybt
Sawtell NSW Australia
I flew my Mavic several days ago only for the second time and successfully took video and pictures.
Since then all I have on my IPhone 6+ is disconnected message showing.
GPS is calibrated but I have a blank screen.
Is this an IMU problem because I've tried to calibrate with the DJI Assistant 2 without success.
TIA...Ross
Common problem is the side connectition you are using.
Pull out both ends from RC and Phone and try the larger USB port bottom of RC.
If that works then it's your lead which is faulty or not giving a good connection.
I believe this is just a disconnected video feed as opposed to the the mavic being disconnected to the rc. If it's just the video feed and you can still control the drone, it's probably just the cable that you are using that's giving you the problem
Marcc
