DJI Flight Simulator - C2 to Confirm
efer
Toronto
I was trying to use the DJI Flight Simulator with my Mavic Mini controller but did not get very far.I can navigate the interface with the controller, but I cannot make a selection because it says "C2 to confirm". The MM controller has no C2 button. Is there a workaround or is this simply not available for the MM?
Reactions: Skywatcher2001
Did you try using the keyboard? There are alternate commands linked to certain 'letters' on your keyboard. I believe (for me on a PC) it was the letters 'A' and 'W' that equated to C2. Read the settings on the simulator program 'if' you are able to toggle over to the buttons.
Good luck!
Reactions: Gindra
Good luck!
Thanks! That worked. Now I'm stuck changing the view. It says "Press the Switch View button at the upper left corner of the remote controller to switch...."
I believe all the keyboard keys used are on the left side: Q, W, E, A, S and Z . . . I seem to remember using them all until I got support for my RC. Try those letters. One of them will work.
Jacob D
