DJI Fly Update?
Matt M PA
SE PA
Good day! My DJI Fly app has an "Update Required" warning. When I click, it gives me 2 options in (what I assume are) chinese characters. The lower one is bold, and I assume the "dismiss" warning...which I use.
Does anyone have an input on this? Thanks!
Aha.. It's probably not the app that needs to be updated, rather the Flysafe database (ref your screenshot). I updated mine quite recently, via the in-flight menu, under "about". Flysafe is the DJI database of no-fly zones, restricted areas etc.
Well, I tried again with the Mini connected...but the upper selection on that pop-up still does nothing. The lower, simply closes the window.
have you updated the firmware to the new version when you do that there is a new flysafe update as well go into the menu and click about to see what firmware you are on should end in a 5 if you are on the latest
Reactions: WooZie
Yes...yesterday while using my iPad, it worked. Didn't want to work with my iPhone. All is updated. I didn't realize about the new manual camera controls...very helpful!
Reactions: old man mavic
pulasthi
