Dji Go 4 app stops then starts
jftman
western NY
I just received a Crystal Sky 7.8 inch and updated both Firmware and Dji Go 4 in a single update from the menu.
On my first flight of Mavic 2 pro the go 4 ap stopped four times then after I click OK it starts up by itself. But after a short time does the same thing, the controller still controls the drone.
Up to this time I have not had to land without Go 4 running.
But I am pretty uncertain wether I will have an auto return bcuz Go 4 quits, and without controller input, if that occurred the landing could be a problem.
What should I be doing?
What version of firmware and GO4 did it update to? Just cerious if it's the latest version that you normally have to go and download from DJI directly. Maybe crystal sky links to that download location on it's own. The only way to know for sure is with the version number.
That will never happen, you can fly any DJI drone with the controller only, No device attached.
There are a few things you can try:
Clear the GO4 cache:
"Me" > Settings > Clear Cache
Standard applications are:
Settings - Browser - Gallery - Downloads
Uninstall, Force Stop or Disable unnecessary aplications like "Amazon Appstore":
From the main screen tap:
Settings > Apps > All
Perform a Factory data reset:
Settings > Backup & reset
GO4 v4.3.60 is the latest version for the Crystal Sky.
ThankYou for all help.
I will indeed check the GO4 version.
When it stops running it auto reconnects pretty fast which is a relief.
Though my last flight it did not first off reconnect.
The app had closed and the screen was the home screen.
I tapped the app and tapped enter aircraft. Tgat meant I had to suffer THE LINK process, and since the drone was airborne no way to press the link button.
All I could think about was running out of battery!
Then the Link button was full bright hot. I hit it and waited……. The screen turned on with navigation.
Checking version it is the latest. And I cleared all cache including the update package.
Jo_Neu
