DJI GO 4, crashes on galaxy tab A
dgrobe2112
I was using my tab A this weekend, with no issues. until i used the dolly zoom feature. im wondering if there is a ram issue, or something.. because while the drone started the dolly zoom, the app crashed.. i had to use the return to home on the controller to get the drone to come back. anyone else have this issue?
... the app crashed.. i had to use the return to home on the controller to get the drone to come back...
If Go 4 crashes just restart it. It only takes a few moments and should allow you to keep flying.
Regarding the cause of the Go 4 crash, I suggest you have the Tab A in airplane mode with no other apps running. The extra processing power to run the dolly zoom may have pushed it past it's abilities. Just a guess since I do not have a M2Z but my older Tab A is rather weak yet runs satisfactorily when set up as above.
Reactions: dgrobe2112
i tried to delete it out of the mavic forum.. but it wouldnt let me.. i will try it in airplane mode.. prolly a good idea..
edit: and i just found the delete.. see if i can delete it..
calos69
