DJI Go4 on Smart Controller with SD Card
UK
I'm trying to edit some of my footage on the Go's app inbuilt editor but it doesn't see the SD Card I have inserted. Has anyone have any experience with this? I can use the controller to view the files and play them back but when I open the Go 4 to edit the footage, it doesn't see the SD Card???
i just purchase the air 2 sc combo pack i also am confused on the sd card stuff i insert the card 64 gb into the drone and it records pics and video when i look on the sc in settings it shows the sd card but when i use the same card in the sc it doesnt see the card and i can not record to the card am i able to use just a card in the sc and be able to record on it or is it only in the drone also when i insert the card in the sc it asked to (default) store on the card and choose yes it restarts but when i record or take pics it doesnt record to it so yes i am also very confused on what that sd slot does
I have the same situation on another drone system. The camera will use SD cards up to 128 GB in size using exFAT format, but the controller that uses a built in Android tablet can only use SD cards up to 32 GB using FAT32 format. You are very likely seeing the same issue here.
Rolling Horizons
