DJI Mavic Air, crashed, arm popped off
mar10029
USA
Hey,
I have a DJI Mavic AIr. I had a crash, and it looks like one of the arms popped off. Doesn't seem to snap back on, cable is intact. Didn't want to try to push too hard, seems to be some sort of spring mechanism in the socket. Any ideas what to try? See photo.
Reactions: RodPad
Hey,
I've never tried to repair one but they do have a spring inside try Google there are videos on repair or wait for someone to come along that has worked on them sorry I'm not able to help good luck.
Thanks! It's odd, it doesn't really seem broken, just like it popped off. It's just when I try to reinsert it, the spring compresses but there's no "catch"
Reactions: RodPad
I'm not 100% sure but I think the spring has to be rewound for tension on the arm kinda like a pullcord but different type of spring . i would wait for someone that has experience fixing them you don't want to break something trying to get it back on
Reactions: RodPad
Try this ...
  • Wow
Reactions: RodPad
Hi, as per the above reply I'm aware you can buy new parts and won't have to replace the whole drone. I guess your fed up rite now but 'chin up' it can be sorted. Good luck
Reactions: RodPad
Wow, that's an incredible video! So cool that someone put all that time into making it. I think that's beyond my skill set, but I also am not sure that's what I need to do. Nothing on the arm actually seems broken the way it looks in the video, it seem to have just become disconnected. I may end up sending it in for repair...
Reactions: RodPad
Hey,
This just happened to me. What fix did you come up with? I cant seem topop it back in.
Hey,
This just happened to me. What fix did you come up with? I cant seempop it back in.
Reactions: RodPad
Hey,
Hey, I have now a fix for this issue. The same thing happened to me, and if you are able to solder, it’s no too hard. You will need to remove the arm, and then take out the spring, for me, the little fork thing has bent out of shape, and to replace it will cost £10, so better than £60 for the whole arm. It’s about a 10 minute job.
Reactions: RodPad
@BenMathew
Your first post and your sharing information. Thumbswayup
Welcome to the Forum!!
Rod ..
@slup
Wow that is a good video!
I watched 3 mins, I would still break at least 3 parts by then. :rolleyes:
Rod ..
@mar10029
Its your thread.
What is your status?
Rod ..
Kazetta
