Hello,
I had a small accident when taking of with the mavic pro and it crashed from 2 to 3 meters. After that i inspected the mavic and didn't see any obvious damage and flew that battery down to about 30-20%.
After changing the battery i encountered a problem where the gimbal clicks around at the startup (The first video). After researching the problem i came across changing the black ribbon cable and decided to check mine and change it just in case.
No luck with that. Also I'm having a strange thing that when i restrict the gimbal movement little bit with my fingers at the startup sometimes I'm able to get the gimbal fully working (as seen in the second video). I'm able to calibrate the gimbal without any errors and gimbal seems to be working as expected... Do any of you guys know what might be wrong with my mavic pro?
Things that i have done:
- Replaced the ribbon cable.
- Taken the gimbal a part and cleaning every part of it so no dust or anything anywhere.
- Downgraded the firmware version of the mavic.
- Calibrated the gimbal with the trick of restricting the movement of the gimbal at the startup
- Checked that the sensor that tells gimbal level inside camera seems to be working (after doing the trick to get gimbal working it shows the level correctly in the DJI app)
- Checked the silver cable in the gimbal and it seems to be fine. I get the picture from the camera correctly. Not sure what else goes trough that cable but at least the picture is okey.
1 Video of the problem:
2 Video of the trick that i did to get the gimbal working sometimes
1 Picture of the damage from the crash. This shows the damage to the underside of the mavic
2 picture of the damage from the crash. This shows the damage to the gimbal
