DJI MP4 files
Jiker69
Gabbs, Nevada
I viewed several of my MP4 files from My Mavic 2S on my Macbook directly off of the SD card, size was about 4 GB. I went to my Windows Laptop and the same files are 4k and obviously won't play.
Are the files not interchangeable or something?
Thanks
It's hard to tell what your question is.
The files from your drone (hard to tell which model you have) can be played on Windows or Mac computers.
If you are having an issue, it will be related to the software you are using.
Reactions: Jiker69
I think I typed Mavic 2S. But yes, I believe it has to do with the different formatted drives.
"I went to my Windows Laptop and the same files are 4k and obviously won't play."
I guess I'm asking why it won't play on both and why on the Mac it shows almost 4 Gig and on Windows it shows 4k.
What you are asking makes no sense.
Perhaps if you gave some details it might help?
The file from the sd card is 4 gig and plays on Macbook
On Windows the same file on the same sd card shows 4k and will not play. Why is this?
If this isn't enough infor (again) then I give up.
"I'm asking why it won't play on both and why on the Mac it shows almost 4 Gig and on Windows it shows 4k."
Obviously the information you are seeing (or think you see) isn't correct.
The video file will be exactly the same size regardless of what computer you play it on.
If the mp4 file plays on one device, it should play on any device.
You've given exactly the same sparse description three times without adding any more information.
Look at the software you are using.
It sounds like mp4 format isn't accepted by one of the programs you have.
How about showing or explaining how you think one computer shows a file size of 4 GB and the other shows 4K.
Clearly that just isn't true.
Thanks
Couple of questions... what codec have you used to record the footage? H.264 or H.265? What O/S is your windows lappie running on?
If you're recording in H.265: Windows 10 doesn't recognise H.265 natively, you have to download the relevant windows codec for anything captured in H.265 to be recognised as a kosher video file. I'm pretty certain the early release Win11 spat the dummy too... I recall I had to search for it and install it myself on my O/S.
This might be the core of the problem... Worth a thought.
Reactions: DubbleURX
Post a screenshot as that makes no sense.
As mentioned above if the files are recorded in h.265 you need the extension for them to show thumbnails in explorer and to play in the built-in video player, alternatively use another player like vlc or potplayer.
I use a Win 10 laptop currently and have recorded footage in H265 which my Win10 OS will not play. I used DaVinci Resolve (I would think you could do the same with other video editor programs) to view the video and render it in H.264 so my Win10 OS could play it.
Hope this helps.
Do you have these installed on your Windows laptop?
Reactions: Eko and SethB
Problem solved! As you can see from the screenshot. 3 files with the extension .MP4 were written to the sd card (4K) from the MacBook in the afternoon. The videos were originally created in the morning and play fine on both machines.
I thought that the Mac could not write to the sd card because of the file format. exFAT I was wrong. In any event I appreciate the help.
Brilliant!
Yeah the ._ starting files are created by the mac's finder. They're greyed too, meaning they are hidden files but you have your settings set to show them. Not the actual video files obviously.
Reactions: Jiker69
Tlaw
