DJI Product Output Power Chart per model/region
Lasidora
Stockport UK
I've compiled a chart showing various DJI models & applicable power output charts, quite interesting to note the subtle differences across different models, also explains why the CE version Smart Controller Ver 1 is down slightly on range for some compared to the stock controller, also note the massive power output jump for the new Mavic 3 Smart Controller (RC PRO) if you are in a FCC area, look at the crap CE power output of the same model over here in Europe though.
So if you are flying the new Mavic 3 & RC Pro controller in FCC land, the penetration through interference / trees etc should be far superior to EU same scenario.
I can see many a FCC hack request for the Mavic 3 as happened to the Mavic 2 Pro coming up in next few months.
EDIT........addedDJI FPV
Wow, impressing list!
How on earth could the RC PRO pass FCC tests?!
Where did you get all this from, or do you do your own measurements?
Do you know if they always transmit on highest power or is the power adaptive?
The values are from DJI's own manual specs shown with each model. not sure if the pwr is adaptive, I doubt it.
Mr. Jeff
