The DJI mavic 2 Zoom and the DJI Mavic 2 Pro are the exact same drone, the only different is the camera and Gimbel. Everything else is identicle, so controllers and other non-camera related assessories will work exactly the same. Also, remember that you will need to pair the controlller to the drone each time you switch. (How to Link the Mavic 2 Remote Controller | Heliguy)Can I use the smart controller with both of my Mavic 2 drones pro and zoom?
Understood and thank you.The DJI mavic 2 Zoom and the DJI Mavic 2 Pro are the exact same drone, the only different is the camera and Gimbel. Everything else is identicle, so controllers and other non-camera related assessories will work exactly the same. Also, remember that you will need to pair the controlller to the drone each time you switch. (How to Link the Mavic 2 Remote Controller | Heliguy)
That’s nice and easy. Thanks for the info.With the smart controller, simply slide your finger down from the top of the screen, select "Switch aircraft" and then select your drone. The controller will connect to that aircraft. No relinking needed.
