DJI Waypoints vs Litchi Waypoints
AntoineD
Worcester, UK
I used to use Litchi when I owned a Mavic Pro, but I lost it and now I'm looking at getting a Mini 4 Pro that can'tuse Litchi. So I'd like to know: are there things Litchi can do that DJI Waypoints can't? For instance, I loved the way you could get Litchi to follow the terrain by choosing 'height above ground' rather than 'height above starting point'. So are there any major differences, and does Litchi still win out?
Reactions: Eko
Yes, there are a number of differences. Some major and some minor.
Arguably, the single most important difference is that Litchi includes their Mission Hub. The Mission Hub provides a way to interactively configure missions using the large screen and comfort of your desktop computer. With this system one can even simulate the flight in Google Earth Pro prior to flying it with a drone. Using DJI waypoints, one is constrained to using the screen of the flying device which is often much smaller than a desktop monitor.
Another important difference is how both Litchi and DJI create a flight path defined by waypoints. With Litchi, the waypoints define the bounding box of the mission where the flight path does not necessarily pass through the waypoints. With DJI, the flight path does pass through each waypoint. Initially, one may thing that having the flight path pass through each waypoint makes more sense. However, having the waypoints define the bounding box of the mission has advantages. There have been cases where people have designed missions using the DJI platform only to find that the resulting flight path passes closer to the ground than any of the waypoints (outside of the bounding box) which can result in a crash. More details about the difference in flight paths can be found here:
As you mentioned, another feature of Litchi is the ability to specify the above-ground height (as opposed to the above take-off height). To do this, Litchi uses elevation data to convert the specified above-ground height into above take-off heights used in the drone.
There are other difference relating to "waypoint actions" where Litchi provides a bit more flexibility than DJI Fly.
I have created a suite of utilities that extend the capabilities of Litchi. One of those utilities can be used to convert a Litchi mission into one compatible with DJI Fly for your Mini 4 Pro. This way, you can continue to use the superior Litchi Mission Hub to plan your mission but then convert it into a mission for your Mini 4 Pro.
There's no comparison - Litchi is great, the DJI waypoints stink. But Litchi uses the DJI SDK present on SOME drones. DJI quit putting the SDK on all but it's most advanced prosumer drones (i.e. Mavic 3E has an SDK). DJI also quit supporting iOS for pads for using with third party apps. This caused Litchi to have to launch a new product - called Litchi Pilot - for drones past P4Pv2. Hoping the first drone in the Mavic 4 line will have an SDK so I can continue to use Litchi.
"DJI also quit supporting iOS for pads for using with third party apps." what does this mean exactly??
In essence all new versions of Litchi wont be available on IOS only android
The current version, v5, of the DJI Mobile SDK is only available for Android; DJI did not release an iOS version.
The previous version, v4, supported iOS and Android. The v4 SDK does not support the newer drones.
DJI's withdrawal of iOS support for 3rd part apps was announced in November 2023
I'm a new pilot. Where can I go to find a beginners guide to Litchi?
I just bought it for iOS a couple of days ago and it works fine. Been using it on phone and iPad.
When you say "it", what are you referring to? The older Litchi app (iOS or Android) is based on MSDK v4 and supports older DJI drones such as the Mavic 2 Pro or Zoom and the Air 2S. The new Litchi Pilot app (Android only) is based on MSDK v5 (Android only) and supports the newer DJI drones such as the Mini 3 Pro and Mini 4 Pro.
If you bought "it" for iOS, the "it" must be the older Litchi app based on MSDK v4 for older DJI drones.
I guess so..."it" was the one in the iOS app store and is flying my Mavic Pro (original) just fine.
If you had a Mavic 3 (or newer), you would have been out of luck if you wanted to use an iPad or iPhone.
I just downloaded Litchi a few days ago and have been working through the user guide and watching some videos. I love the mission hub for waypoints, here is my specific question: I have created a 15 point mission, no curves, 3 POIs, and at each waypoint I identify the POI at which I want the drone to look. I cannot find how to make the drone take a photo from each waypoint of the POI at which it will be looking. I'm flying a Mavic 2 Zoom. Thanks for any advice.
You would set up camera actions at the waypoints where a photo is to be captured. In the Mission Hub, select the waypoint. A waypoint dialog will appear. Add any appropriate "actions" to this waypoint.Capture.PNG
You would set up camera actions at the waypoints where a photo is to be captured. In the Mission Hub, select the waypoint. A waypoint dialog will appear. Add any appropriate "actions" to this waypoint.View attachment 184381
Thank you. On my laptop that waypoint dialog did not appear automatically, I had to click the tiny + sign way at the bottom to bring it up, then all the actions were available. I plan to fly the mission soon to see if it works as advertised. Some comments on this topic suggest getting photos during Litchi waypoint missions can be a bit hit or miss.
askacfi
