Dji waypoints
Mavic-Max
Nottingham UK
Hi folks. I’m in England and have a MA. When the MA is not connected to the controller I click on the controller Sunak and waypoints shows but it says it’s not usable till the craft is up in the air. When I power on the MA this option is not available. I’m sure you e been asked this before but I can’t find info relating to this. Any responds greatly received
Reactions: Lastrexking
Morning mate. That's curious - the Mavic Air was originally advertised with Waypoints, but they never materialised and DJI later backtracked on them. Can you do a screen grab?
This is what I see before the MA is powered up. When a icon is selected it says cannot enter this mode. View attachment 96921
Yeah, that's only there because your Air is disconnected. Go4 is used across the Mavic Pro as well, so as it doesn't know which drone you have it defaults to the option for the Pro. Once you connect your Air it Go4 will show the options for that drone.
The only way to use waypoints on the Air is through Litchi.
I have a question related to Litchi waypoints fly. In case of a signal loss does the MA keeps going thru? does it follow the waypoints until it finish all of them? I have it configured for RH after mission finish.
It depends on this setting:
Reactions: Franco7
GLobus55
