DJIGo4 camera settings remains when switching to Litchi? Mavic
bjorngronvold
Hi
I use both DJIGo4 and Litchi.
When I adjust camera settings manually in DjiGo4 and are happy with the result; I then switch to Litchi, (both apps are in manually camera setting mode) I see that the ISO and shutter is the same when I switch to Litchi, with the Mavic running and connected.
With Litchi active and DJI in the background I can see that some of the settings; ISO and Shutter is the same as it was in DJIGo4, but I am not sure whether Litchi keeps the other Go4 settings or if Litchi override some of the Dji Go4 settings once it becomes active?
Anyone who knows?
I'd like to know this as well.
All of the settings are stored on the drone. Which is why the drone must be turned on and connected whenever you tweak any settings. So yes, all settings will be the same between apps.
Reactions: whiskeylover
zafersari
