DNG files are present in app, but not showing on card reader
AdeptAir
Asheville NC
Problem?
When the drone is running, I can press the button for the image gallery and see all 184 of my DNG files from today through about 6pm. When I remove the SD card and plug it into my card reader, it looks as though I stopped taking pictures at 1:25pm and only have 17 images. Around this time I got a "slow SD card" warning from the drone and had to eject/re-insert, turn drone off/on and then it started working again. This is a 3 month old SanDisk Extreme Plus 256GB SD card. Where are these images and can I/how do I get to them? Is there an issue with the SD port in my drone? I had this issue with an older card that I thought might have been worn out after extensive usage, hence the new card, but now I'm not sure. I'm hoping someone has some insight into this because I'm going to have about 170 miles to re-drive if I can't sort this out.
Was unit in a crash?
No
What have you tried so far?
Removing/re-inserting card. Attaching drone to PC through USB (no effect)
What device are you using ( iphone , ipad, Samsung , etc)?
Google Pixel 9
What firmware are you running ( aircraft, remote controller)?
Not sure
What Go app version are you using?
I've been using Litchi for a while. Google play store stopped carrying DJI Go and my phone would shut down the app when I installed it directly from their webpage.
Any modification?
(if so what)
No
Did you change anything or install any apps? (if so what)
No
Do you have a video or pictures of the problem? (if so post link)
smhhjoshh
