Downlink Lost
Depending on the DJI model and settings, it will auto select a channel either in the 2 MHz range or 5 MHz range, and while in flight switch channels as the WiFi signal strength changes in flight.
It is an original Mavic Pro 1. I was not flying in WI-FI mode. In the manual, I found where it says the remote controller's operating frequency is 2.4Ghz - 2.4835 Ghz. I have emailed the manufacturer of the smart water meter to see what it's frequency is...but I found this via google:
People also ask
What frequency does a smart meter use?
2.4 GHz
Inside the home, Smart Meters usually use wireless signals at 2.4 GHz, with a maximum power of less than 1 W. This is a similar frequency to several existing wireless technologies - WiFi, Bluetooth and ZigBee for example. Some Smart Meters use the actual ZigBee system, and powers may be significantly less than 1 W.
I’m surprised no one has asked for the log files. As it’s a Mavic Pro (1) the drones logs might be readable.
Geometry makes the most difference. Radio frequency signals increase or decrease with the square of the distances, so it is best to use the DJI auto function, as the geometries from flight are almost always changing.
Is this a file in the drone or in my phone? If in the drone, how do I retrieve it?
NVM...I just saw this:
Just a quick update...
I finally received a response today from the manufacturer of my smart water meter....says it transmits on 956Mhz, and only for 1 second and only when requested by the meter reader...so I don't think that was the cause of my connection issue...
Anyway, have flown about 2 or 3 batteries since with no issues...very strange...I have no idea what happened.
tortoide
