Downloading DAT logs from the drone, a couple of questions
  • Thread starter Thread starter Deleted member 103366
  • Start date Start date
D
Guest
Using the assistant I can successfully download the logs individually or by 'type/subject' via the "advanced" mode and the process runs something like "downloading" then "compressing". When compressing finishes a "complete" button appears and pressing that takes me back to a screen where I can make the next selection. However if I do it in the "normal" mode the process does not seem to indicate that is has reached a conclusion, the download indicator reaches 100% but then just sits there. In the assistant, to escape from that download process, I have to select another function, such as simulator.
Is the normal download process supposed to do anything else other than stick at 100%? Obviously I can not check the contents of any downloads but going by their size some downloads work and some do not (Mb vs 1kb).
If all I am supposed to see in "normal" mode is the download indication, how long am I supposed to leave it sat at 100% before the full sized file is supposed to appear in the storage folder?
Thanks
Thanks
Phil,
I thought the dat files on the macic 2 ac are encrypted. In any case next time I get back I will see if I can download them on mine, probably not till the weekend
dvkhamtruocsinh
