Downward Sensor Calibration issue on my Mavic 2 Pro
RedBaron2
RE: For the last few months, I have been receiving a notice on my Smart Controller of a need to calibrate the downward sensor on my Mavic 2 Pro. No landing problems have been experienced. I have not found any directions to resolve this issue. I prefer RTH landings but will also perform manual landings as well. No apparent difficulties. I would appreciate any guidance that this group would offer. Thank you.
Reactions: Cafguy
1. Calibrate it.
2. Clean it.
If these two won't clear the error, you need to replace the sensor.
Is it damaged? Any hard landings?
Reactions: Felix le Chat
1. Calibrate it.
2. Clean it.
Agreed. I've had the same error for well over a year. Several calibrations with no help. Never had any hard landings. I always use manual landings, and the drone descends gently as designed. The sensor needs replacing. I haven't replaced it as it hasn't caused any problems for me.
Reactions: Cafguy
Reactions: Lens
Usually you get access to the visual sensor calibrations through the DJI Assistant 2 software.
You can find the version for Mavic 2 here --> Mavic 2 - Download Center - DJI
Still working on resolving a downward sensor problem. Not working.
My thanks to all contributors. Please excuse my ignorance. Please understand that you are dealing with a really old and not mechanically-inclined drone pilot. But, I really enjoy flying the Mavic 2 Pro and I do not want to lose it. Originally, I checked the Smart Controller for guidance on downward sensor calibration. Nothing seemed to work. Cleaned the sensor surfaces; no improvement. Guidance from this forum inspired me to resolve a potentially serious problem. Not there yet, so I am looking for further guidance. As guidance for others with a similar issue, I offer the following as a report/checklist of progress so far.
1. Unlinked my M2P from my smart controller.
2. Relinked to the original controller.
3. Downloaded DJI Assistant 2 to my home Windows PC. Appears to be compatible with my equipment.
4. Identified on the M2P a small rubber panel that provides access to a computer connection. It appears that it provides connection to my home PC. Is that accurate?
5. Encountered low-battery issues with all equipment (Mavic 2 Pro batteries, Smart Controller and my Original Controller).
6. Now recharging all batteries.
7. As a next step, I plan to connect the M2P to my home PC for the first time.
8. Assuming that works, what should I expect to see on my PC screen? Where should I look for the page shown above on this page?
9. What should I expect as next steps?
Thank you from a really old drone pilot.
Ron B
...Not there yet, so I am looking for further guidance.
Try this... & before you start, fully charge the drone battery.
Reactions: RedBaron2
I see two more pilots with similar calibration issues. My progress report applies to all of us.
10. As directed by SLUP (thank you) in the YouTube video, I downloaded Assistant 2 to my PC.
11. Connected M2P to computer, and turned it on.
12. Then, I needed to download from DJI two separate updates for the Assistant 2. Quite a lengthy process.
13. Once fully downloaded and re-booted, it was easy to identify the calibration button.
14. Good advice from "slup": "Try this... & before you start, fully charge the drone battery."
- Reviewed the YouTube tutorial several times.
15. The actual calibration process takes a lot of time and patience and repeated effort after several failed attempts. A stead hand is strongly encouraged.
16. I do not have a steady hand but I will try again tomorrow.
PS, I have seen some progress. Good luck to others with calibration issues.
gimfbsx
