Drone Registration Help
Dincena
Queens, NY
Hey all, where it the best/offical/legit website to register a drone for recreational use? How much does it cost? I'm seeing a few different websites with different rates ranging from $5-$30. How would i know which one is legit?
The only site you should use is what WWK888 provided, its $5 and you are actually registering yourself as a rec flyer. The reg number they give you is to be used on all your rec drones. The process is simple and straight forward it should take you about 5 mins.
I bought these stickers on amazon for my reg, the only problem is you have to be really precise when applying them. You can make minor adjustments afterward, but it's very difficult to get straight lines with this method
Make sure it is FAA.gov. Then there is a drone link on the right side of page. Only $5!!
Reactions: dawgpilot
utahloanrelief
