Duration of battery charge
Darkabaz
Netherlands
How long does it usually take to charge the battery in the charging hub? In my situation it takes almost 18 hours for just one battery. (10%-100%) I use a 5V 2A charger at the moment
What is normal?
No- that is not normal what model Drone are you charging and I can help much more
Assuming this is an Air 3, you need a 60W+ USB-PD charger. 5v 2a isn't going to cut it.
Reactions: rp6 and Xi Zhou
What is normal?
5v 2A is 10w, when 65w or 100w is what is suggested.
Mine charge in under an hour with 100w.
Reactions: GadgetGuy
What is normal?
That's normal for a 10W charger. You need 65-100W for 60-80 minutes.
Reactions: Xi Zhou
Had the same problem. See my thread.
I bought a 100W Charger from Amazon now it loads really fast :)
Reactions: Xi Zhou
DevonAnkunding
