excessive gimbal vibration
eddillenbeck
Hi Droners! I only have 10 min. on my Mavic and have severe oscillations causing a error message- something like "excessive gimbal vibration". I changed the props and checked to see if motor mount screws were loose but they were tight. I don't want to run it like this and thought I'd check this forum before contacting DJI.
Is this something I can smooth out with the DJI go app?
Thanks!
It may be the actual cable itself. There's a video on YouTube that shows how to manipulate the cable and clear it. But, before you do that place on a flat surface and calibrate the gimbal
Sent from [emoji211]
I think I may need to turn off the Prop Guard toggle in DJIgo app but can't figure out how. Thanks
Had a run away last night trying to photograph July 4th fireworks. Crash! No significant damage except excess gimbal vibration message. Thanks to posted sketch and youtube video for solution. Problem Solved and back in sky! Big thank you!!!
sba6
