Experiments can be interesting...
Jeff A
Well Worn Member
Elk Grove, California
Experiments can be interesting but may not come to an end. Today, an experiment I started over three years ago produced some results.
In early 2021 I shot some HDR photos and posted them in an Album on Flickr. After posting, I discovered that this was all a waste of time because, much to my surprise, my high end computer and Monitor could not display HDR content. I worked these issues for some time but finally gave up because I just was not able to make it happen.
This morning, while comparing new monitors with my present 27" Dell 4K monitor, I attacked the problem once again. I was able to figure out how to turn on HDR capability on my monitor, and then after much searching, was able to configure Windows 10 to display HDR. I then took the 1st HDR shot I had taken with my previous Mavic and viewed it. I was presented with an image full of noise. I normally use the DeNoise function in Lightroom to de noise my photos but my photos had been converted to JPG's and Lightroom can only work on DNG's so far. Fortunately, I had purchased Topaz DeNoise AI which will work on JPG's.
If any of this is of interest you guys, you can compare the first two images in my HDR Drone photos using this link: HDR Drone Photos. I'll wait a while and then de noise the remainder of the photos.
Jeff A
Reactions: AeroJ
I have found with the Topaz products to play around with their settings, as you can get different results when you do. Usually for the better, but not always. For example instead of using the Severe setting, try the low light, etc.
I assume you were still on the subject of HDR??
Well, here are my final rethought and discoveries on the subject. First of all, my monitor. I did find a switch to turn on HDR capabilities, only to discover later that full HDR offers the abilities to see 4 more stops of light, but my monitor only shows one additional stop of light. I would have to buy a new monitor to enable all of the HDR capability. For me, that is an expenditure of over $1400! That is not in the cards for me at this time. The next thing was the real killer though. I display over 5,800 photos on Flickr and I love Flickr they will never down-res your photos and it's a flat fee with no limit on photos. The bad news is that Flickr does not support HDR. So, that project has come to an end for me, for a least the time being.
Thanks for those who followed this subject. Side note, a link to my Flickr albums.
destinyrett
