Expert Drones
I've never seen any type of warranty for DJI products that allows customers to dissemble the aircraft to remove the defective part, send it in, get a replacement, and repair it on their own. There are likely many reasons this process works like this -- here are a few:
  • Repair work done by an unauthorized party can void the DJI warranty
  • It would be impossible for the warranty provider to confirm the part in question is the problem
  • It would be impossible for the warranty provider to test the aircraft after replacing the part
  • Allowing the warranty provider to do all of the work could eliminate a lot of potential back and forth
  • Customers could break other parts while attempting to remove the defective part
  • Customers could abuse the system by sending in parts from aircraft not covered under warranty
If you want to the real answer, you should probably ask Expert Drones.
Reactions: Merlin23 and halley
RTLflyer
