Explore mode without digital zoom on 3 Pro?
16x9frame
St. Louis
Is it possible to switch between the three cameras on the Mavic 3 Pro using the zoom wheel control? I do a lot of video shooting of high-action scenes outdoors in the cold with gloves on, and would like to be able to quickly switch between the 3 cameras using the zoom wheel. Basically just like it does in Explore Mode, but without any digital zoom (digital zoom noticeably reduces the picture quality unacceptably). I didn't see anything about this in the manual. Thanks for any advice!
I don't think you can use the zoom wheel to switch between cameras the way you want. I just checked to see if it was an option on my RC Pro controller and it is not an available option for the zoom wheel. Other settings like ISO and aperture can be changed using the zoom wheel but not changing between cameras. I use the C3 button on my RC Pro to quickly switch between the 3 cameras.
Chris
Chris
Hi Chris ,
Does videoing have to be stopped to switch between cams ?
You need to assign a button to change from camera to camera, and you'll need to stop recording when you switch; else you need to use the explorer mode which goes through the digital zoom.
Hi Chris ,
yes . i have the small button in the far right as a lens changer . But i must stop filming . The button will go 1x 3x 7x then back to 1x . find what u want then continue filming .. Maybe Mavic 4Pro will have continuous zoom !!
osje
