FCC in CE area mavic pro
Matty609
Hello everyone, this is my first post.
I would like to know if there is any safe way to switch from CE to FCC for increasing the signal trasmission.
Is there any method I would be able to do that?
I have tried by using an android device with fake gps but it didn’t work .
Thank you
You should not have to switch it and I do not believe you can with the MP - you are prob in beginner mode - leave it there till you get the hang of things then take it out of beginner mode then you will get LOTS of distance.
Thank you
Try the search function on the forum.
This has been covered soooooo many times already.
It can be done to boost your signal, but that is going to take some modification of the aircraft firmware and/or your controller. But don’t be too quick to do any of that. For some modifications, you could mess up your equipment if you don’t know what you’re doing. It can get serious and costly.
I’d wait until you have numerous hours of flying under your belt, and have a solid reason to make any modification, like overcoming extreme attenuation from trees or buildings in your common flight area. Then if you’re ready, look at the “modifications” forum. There is a lot of heavy duty stuff in there.
FCC vs CE is theory. I'm living in a CE zone and I made a lot of Litchi flies of 3..4 km long. In my opinion you cannot do more safely, because of the battery limitation.
Welcome to the Forum from the Nature Coast of Florida! Take advantage of this Forum and read it everyday. I do, like the daily newspaper. There is much to learn from hear. Questions? If you can't find it, ask!
Riiich23
