So it looks like they want me to update the firmware before flying. But isn't it for e the Magic 3? Who has updated who hasn't?
Thanks
Thanks
Thanks for the replyIf you connect your mavic air 2s and it shows a firmware update, then it means that there is a firmware available for your drone too, not only for the mavic 3. Don't confuse app updates with firmware updates, both of them should be done.
I just upgraded my air 2 a few days ago to version 1.5.4,and the firmware.turned on my tablet today and it told meIf you connect your mavic air 2s and it shows a firmware update, then it means that there is a firmware available for your drone too, not only for the mavic 3. Don't confuse app updates with firmware updates, both of them should be done.
Always fun to read some of the posts of people that do updates then find out they should have waited because of some bonus feature that DJI added in to the mix that they truly could have done without.If you connect your mavic air 2s and it shows a firmware update, then it means that there is a firmware available for your drone too, not only for the mavic 3. Don't confuse app updates with firmware updates, both of them should be done.
That's right, but not every firmware update has a battery update, only some of them do.I have updated the latest firmware (driving a MA2) and all seems fine. I learnt from pals on this Forum that if you have more than one battery you need to stick each one on the craft and complete the firmware update. Apparently the batteries get updates too. Suspect dji want to ensure we are all aware of the M3 which is why the info on the update leads with their most recent launch and doesn’t really give any info on earlier models that might be covered within the update. I could have this wrong though so will see if anyone corrects me.
My first post.That's right, but not every firmware update has a battery update, only some of them do.
Agree with this 100%. Every time I popped a different battery on the craft (after I had done the main update), it said New Firmware Available.Battery updates are indicated by "Firmware avalable" messages, in my case indistinguishable from full updates. If I get a message within a day of updating, it usually means I missed a battery. Only some updates change Battery firmware, but when they do, you will get notification of Firmware available every time you pop in a battery not up to current levels.
Fortunately these usually take only a minute or 2, and the code is already downloaded and staged (meaning you can complete the battery update in the field)
Be happy it's not an Autel, which makes you run the entire Firmware update, in full for each battery. You can boost the time it takes by putting the code on SD card, running it, changing batteries, erasing the text file that says complete, staging the FW to the card again and repeat. 4x in my case for 5 batteries. And this is the fast way. Doing it wirelessly takes 20+ minutes. So I don't want to hear complaints, LOL!!
