Flight Log
You can find instructions for locating, uploading, and viewing your TXT flight log online here. Once your flight log has been uploaded, you can download the generated CSV file and print it if you'd like.
Reactions: Mario T and jayefs
I didn't think I'd ever need to do this but here goes. I was flying my Mavic about 2500 feet away in a pasture. I suddenly lost signal on the screen, no video, no controls, however the controller was still providing info. I did what I've done before. I started flying slowly in a direction that showed my distance decreasing on the controller. However, at one point it reversed and started going up, so I just pushed RTH. I should've done that sooner as when the drone came back it flew over a neighbors home, several of them outside. They were offended but accepted my explanation. Now I'm trying to see my flight log to see what exactly happened and see that flight route. I can see my flight on the controller up to the point of losing signal with the phone but nothing else. I wonder if I saw a flight log if it would provide more info but can't seem to get to it to be able to upload it. Note the two photos. I do not see a Flight Record Page, nor a SD icon or Resource Manager when I open DJI Assistant 2. Is there a step by step process someone has prepared? Does it matter which version of DJI Assistant 2 is used?
DDixon69
