Would love to know the answer as well. Settings for flying indoors. I would think you want to disable sensors and fly carefully. But how do you turn off GPS?Thinking about fly indoor to take some cool shots for our private basketball events.
Do I need to do some special settings?
I don’t want the drone to cut in and out with poor GPS signals, or start doing some “failsaf things because of lack of GPS signal.
Thanks
mavic airThis is possible, but with many perils: Here are some best steps:
Short answer: if you do this regardless of the warnings (and only if you get permissions), do it in full ATTI mode only (a Mavic 2 does not come from the factory with this), after lots of practice, and have plenty of liability insurance:
Maybe there's another craft that's better at this, but I wouldn't do it with a Mavic or Phantom, even with full ATTI mode.
- You need to try it and practice it with an empty court, many times.
- But even then, if your lose control with a court full of people later, you're looking at a lot of liability. Have plenty of insurance.
- You will definitely need permissions from those in charge. You probably will not get that.
- You WILL lose GPS signal, and so will have no lock, and your craft will drift (ATTI mode). There IS NO setting that will guarantee GPS lock inside buildings.
- Sometimes in such situations, you get really bad GPS (not just on/off, but unreliable) signals that will cause your craft to do more than drift, so this basically means an out of control drone that goes zooming off to the side regardless of stick inputs
- With another drone, a dedicated ATTI mode (turn off GPS) would be best so that it was not cutting in an out. But the Mavic 2 does not have ATTI mode (without hacking, there are other threads for this)
- ATTI mode is another mode of flying that you need to practice and be good at. Since their is no GPS lock, you need to compensate for drift (in all directions), which is better inside without wind, but still means that you cannot just let go of the stick and expect it to stay put. So this means constant attention and definitely constant VLOS (you shouldn't be distracted by your screen). So if you do find the ATTI mode hack, you should do lots of practice. But I still wouldn't do it (see step 2).
Chris
easy to fly indoor....less things to change on the settings...a little loud..why mavic air?
