Foldable Extended Landing Gear
i have some similar type landing gear that clips to the bottom of my MM mainly because during the gimbal start up dance the camera will get hung up if the ground is not reasonably flat if i want to take off without my Landing Pad
the design of the Mini 3 means that the props are considerably higher off the ground and the gimbal start up dance movement, by comparison to other drones is very minimal , so i dont think these legs are really necessary for me anyway
i have noticed that when landing mini 3 in a field or garden obviously looking for better place flatter ground etc.. otherwise they will slice through the grass, they do make a good little lawn mower.
I carry a hard landing pad in my bag - works perfectly and you can throw it on grass easily:
Folds up quite small
I have not received my Mini 3 Pro yet but I did purchase this Mini 3 landing pad. This photo has my Air 2S sitting on the landing pad. The other photo is the pad on a iPad 7 inch. I don't know if the Mini 3 with land on the pad in the wind but it will be fun trying to do so.
I have one like that too - it kept blowing away and I got fed up chasing it (and couldn't be bothered pegging it down), that's why I swapped to the one above. It's heavy enough not to move!
I liked this one, "does not effect flying". It literally means it stops it from flying. I don't think that's what they meant, though 🤣
fisterc
