The two main complaints are the NFZ updates, which are not accurate at the best of times, easily solved as stated turn off GEO.
Second is autoland, abort from the upward control stick being ditched. (Meaning if the AC goes into auto land, which with 0500 it sometimes seems too when the senors are confused you can not abort autoland as you previously could).
@msinger did some testing and the result was autoland can be aborted with the sport mode switch or by turning off the landing protection which seems to negate the autoland feature from initiating.
