Gimbal Issue, it it going nuts!
jocampo0229
I was flying my Mavic around today. Battery was low so I brought it back to swap out the battery.
After I replaced the battery, I booted the drone back up. The gimbal would start to initialize and then go crazy!
I have attached a link the video. Does this need to go back to DJI?
IMG_7713.MOV
IMG_7713.MOV
Wow! That is the serious Mavic gimbal disco shake!
I almost want to go to bed with that one. :D
Seriously though, I would try to calibrate the gimbal first.
Try another battery as well to rule that out if you have one.
What FW are you on?
Reactions: Former Member
I am on the latest firmware.
I have tried to reset and calibrate the compass, and IMU.
currently charging the other 2 batteries to see if they make a diffrence. It's crazy because it was working perfect fine. Drone has never been crashed and only has about 6 hours of flight time on it.
****. And I thought I had gimbal overload issues. Jesus that thing is shaking more than Shakira's hips.
Let us know after you have recharged the battery and used the same battery you had in it before. If it stops, then try the other batteries again. Could be a firmware issue.
GLobus55
