Gimbal Jogwheel counter-intuitive
zaldy
Indonesia
I fly Mini SE with Fly App (1.4.8 - 1120)
I found the gimbal jogwhell direction is counter-intuituve... Mini SE uses same controller as original Mini.. Jogwheel located on the left side controller.. as you push (slide to right) the jogwheel, camera will go up.. you pull (slide to left) camera will go down... for me, this is counter-intuitive..
what should have been, you push wheel - camera down, you pull - camera up... thats the way i think our brain uses to (in correlation to gimbal jogwheel)... push down, pull up
yes, i know "muscle memory" and so on... but after 2 month daily practice, i still feel that jogwheel is messing with my brain.. i already have muscle memories for control stick.. but gimbal control.. ****, often time it messed some of my shot...
so, any of you feels the same? or you guys are not overthinking it and developing muscle memories? (especially with camera wheel)..
I feel your pain. It took me a long time to get used to "jog wheels" for the gimbal since I was in the drone thing early and used sliders on the back of the Tx - which I still prefer. You would think that all this being computerized it could be easily set to pilot preference.... It should be an option in the app. I can't say that I've even looked for such an option come to think of it?...
Yes.. this should solve quickly if only there is setting on DJI Fly app to "reverse" gimbal movement... sadly, there is none, isnt it? i search for every setting in app, i could not find one
I simply think of it as push up pull down, or at least I try to ............after I have gone the wrong way .
I read similar post in DJI Forum, where this mnemonic push-up, pull-down should memorized when fly.. i'll try it in my next flight..
My solution....labels on the tablet....still doesn't always work... :confused:
I guess "out - in" refers to zoom function (which my Mini SE doesnt have that feature)
Even zoom direction they get it counter intuitive :D.
If it was me design the wheel, i'll put zoom in - slide left, zoom out - slide right...
As i stated before.. our brain still intrepret push movement (as if "push" your finger either left or right, in case of zoom function) as some "in" or "down" .. i definitely dig push as down or zoom..
Well DJI, in other hand.... :rolleyes:
Reactions: Barbara
I am so glad to see others having the same problem I do. Thanks @zaldy for posting this!
Reactions: Barbara
How's about thinking of it as something on a high shelf. You push that up and pull it down.
advancearch
