Gimbal Rebuild Question
SkyFixer
Ponte Vedra, FL
Can anyone provide me with direction? I am rebuilding my Mavic 2 Pro Gimbal assembly and am unable to attach the camera module to the yaw arm. The original yaw arm cracked at the ring, releasing the camera. I ordered a used yaw arm. The replacement yaw arm I received has a "button" in the ring which I suspect was part of the camera and was just left on since it is hard to remove. Please see the attached photo. The red arrow to the left is a stock image, the red arrow to the right is my replacement arm with a button in the ring. The blue arrow is the existing camera which needs to be inserted but cannot because the button is occupying the space. Am I correct in the situation? How best to remove the button (if that's the case) without damaging the ring? Thank you for your attention.
I have no idea
Reactions: sarahb
Picture of the opposite side of the right red arrow?
I think what you show in the picture(right red arrow)is the bell for the motor.
Thank you for responding. I'm not sure the nomenclature. It's hard finding a schematic of just the gimbal assembly. Any followup is most helpful.
From what I can see, looks like you would need to press the piece out of the 6784 image. Once removed, your new piece would take its place. It is possible there may be some type of adhesive used by DJI when they assembled this part of the gimbal.
Without the proper tooling, this would be a bit tricky.
Thanks for responding and I agree. It is in fact snug. The ring has a dual diameter interior that allows the piece to snap in. It just so happens that piece is usually attached to the camera. Its tricky to press out without the chance of snapping the ring, which I guess is vulnerable to breaking in the same area (I've had two drones break in the same area). I had it in the vice and you can probably see the scuff marks and indentions from tapping it. An other option is to cut the ring and then glue back.
They simlpe pressed in very light but with a glue that you can scrapr and clean up then you can press the other in with your fingers I would probably use e 6000 pro
Reactions: SkyFixer
Thanks Starz. It was in the back of my mind, but your post cemented that I needed to "press it out" rather than taping on it. So, I bored out a 5/8" piece of scrap, set the ring on it, and then proceeded to tap out the button. Oh, and I heated up the ring with a heat gun prior to the procedure. All good, success!
Reactions: Starz
kaidoestech
